output directory
Berndt
output directory
Post by Berndt »
is it possible to store the output files automatically in the source file directory?
Many thanks in advance!
Bernd
Helicon Focus 8.2.2 Pro Lifetime
Re: output directory
Hello Bernd,
It's possible with the "Save all" function (Ctrl + Shift + S).
Berndt
Post by Berndt »
Hello Catherine,
when I drag & drop a video as source then it does not work to store the output files automatically in the source file directory with the "Save all" function. But I need that function.
Bernd
Hello Bernd,
That is because the source frames are in a temporary folder, and if you place your result there, it will be wiped out when the folder is cleared. In other words, you don't want to store the result alongside the original images when importing a video because you're not even supposed to know where the original images are.
