Canon R10 issues
Olsen
Canon R10 issues
Post by Olsen »
Hi a have a 2nd hand FB tube, with the cable.
It works fine on my Canon 6D with the 100mm 2.8 IS macro @f/8
But on the Canon R10 and the same lens and settings nothing happens.
I guess if it doesn’t work with the R10 it probably also doesn’t work on the R7.
Does anyone have similar experience? Maybe found a solution?
Regard
Per
Re: Canon R10 issues
We don't know about these two specific models, but generally the FB tube does work with Canon R cameras, as long as the aperture is not at its widest position. For example, with a 2.8 lens you can't use the 2.8 position.
Ifylk
Post by Ifylk »
Hei I use the tube on R7 and ef-s 60mm macro and adapter. this combination works with no problem for me.
mvh IF
