Hallo,
I would like to test all stacking-methods (A, B and C) in a single batch-process. Is this possible?
Kind Regards
Rainer
Batch-Processing
Re: Batch-Processing
Hello Rainer,
There is no built-in function to do that, although we want to implement one.
The closest you can do is load your stack into the main interface (not batch) and simply change the method and click "Render" for each desired method to queue up the stacks. But if you have many stacks then there is no simple way, I'm sorry. Using the command line interface might be the best for it.
rainerteubner
Hallo Catherine,
thank you very much for your answer. So I have to wait for a further release of the software.
Kind Regards!
Rainer
Kind Regards!
Rainer
