Artificial intelligence in the future
Klinke
Post by Klinke »
Although your difficult situation you are doing very well ... for example all the new necessary updates for the Mac system :!:
But there is one thing I would like to be improved - if possible. 8)
Because of the high resolution of the modern cameras on low aperture I am quite often trying stacks for landscapes.
Often that works really fine using 5 to 6 pictures. The only big problem is the wind.
Quite often things like gras or branches are double (or often) in the ready picture what means a lot of corrections afterwords - if possible at all.
So what about using artificial intelligence in the future?! That could be the perfect solution, couldn't it?!
Klinke
Re: Artificial intelligence in the future
Post by Klinke »
I did have it again on the weekend ... a 'landscape' stack ... only 5 pictures necessary but very low floating water and some blades of grass made it impossible to use the result. Would have taken hours to rework, if possible at all. :cry:
I am wondering if artificial intelligence would be able to recognise and correct on their own.
Catherine are you thinking of things like that at all - or do you think that is impossible?!
Hi! It's probably not impossible in principle, but it's not something we're currently pursuing or thinking of. A year from now you will probably not have to shoot any photos at all, you would just describe what you want to see and a realistic photo will be generated. There will probably also be services for correcting issues in the photos.
Klinke
Post by Klinke »
Nice future to come ... :(
That might be the beginning of the end of creative photography.
I do not want to get any realistic photos generated.
Doing that on my own, in the nature, in the field is what gives satisfaction - as much as possible done be me.
However you may be right and the train is 'on its way'.
I understand you very well, and my prediction is probably exaggerated, but we will definitely see more progress in that direction soon.
Klinke
Post by Klinke »
Just seen in a new post above ... I did not know about the sense of those settings ... :wink:
https://www.traumflieger.de/reports/Mak ... :1661.html
That's not special 'intelligence' but it definitely helps to eliminate some unwanted details like double blades of grass.
Not perfect, but helpful.
