Source Image Error message
dElegance2008
When attempting to process multiple 120MB, 16bit, TIF files scanned with a Nikon 5000 using small radius values, I get a Source Image Error message that says "the dimensions of the first and current [filename] images are not equal. Current image will be ignored and deleted from the list if you continue processing. Do you want to continue processing." I've aborted and tried again and sometimes it processes as normal, sometimes I get the same message until I either increase the radius size or change to method A or both. I have version 4.50.3 What does this mean? Thanks.
