Batch mode is central to my workflow. I typically load several thousand images off my memory card, then use auto split to divide the images into stacks ( typically 20 - 50 stacks ). I'm using Raw to DNG.
Then I render them with some initial default settings, delete some (most) output images, and re-render others with different parameters and sometimes a crop rectangle.
Next, I retouch the images I want to keep from input source files and from other (corresponding) output files.
Finally, I save the handful of "keep" images to disk for the next step.
The problem is, in a high percentage of cases Helicon crashes or hangs before I can complete this final step and I lose everything. When Helicon hangs ("Not responding" in the title bar), Windows 11 Pro has a very hard time shutting it down (whether Windows UI, Task Manager, or Reboot), it either takes a very long time and eventually shuts down, or takes so long that I lose patience and have to hard reset my laptop.
Sometimes, there is a precursor to crashing when I attempt to retouch one output image using another and the output image dropdown is empty even though there is a suitable image in the output list. It usually crashes soon after if that happens.
Please let me know what info I can provide to help make this more stable. Memory cache limit is set at 40%. I'm probably stressing this program more than the average person, but the way that I'm using it is really the way I need it to work. Thanks!
Frequent hangs and crashes in batch mode
Re: Frequent hangs and crashes in batch mode
There is absolutely nothing wrong or unusual with how you're using the software, it should be perfectly capable of handling your tasks as long as your computer has enough RAM.
Please reproduce the problem, wait for it to freeze completely, then terminate the HeliconFocus.exe process (or restart the computer if you can't do that). Then reopen Helicon Focus and send a bug report: menu - Help - Contact support.
clausgiloi
Ok, I have submitted just now - had the same problem. I want you to know how much I appreciate this program and don't want to sound like I am always only complaining. I do appreciate your help with this. Thanks.
clausgiloi
I just repro'd the crash and submitted a new report, got the "Thank you for contacting us" popup. I will send separate email. Thanks!
