Problem with Performance when using Helicon Remote
joanmills
Post by joanmills »
I have a 2012 Nexus 7 that works FINE (at least as well as most anything) with Helicon Remote. Had a charging problem and bought a Nexus 9. One of the things it has to do is work properly with Helicon Remote. HR takes the feed from the camera live view and lets you do camera control, select focus points, and so on.
Unfortunately, when connected to my Nikon D810, if I move the camera, only the far right edge of the screen updates. Then after several seconds, the rest of the screen finally updates. When zooming, you get the right edge updated, and tiles displaying and sitting and flickering on the screen. Again, after several seconds the screen finally updates.
Since it works fine with the Nexus 7, I presume there's some difference in the 9 that's having a problem. I don't know if Helicon Remote needs some update, or if its the tablet.
Can anyone provide ideas for getting rid of the huge screen lag? Is it possible to change (reduce) the resolution of the Nexus 9 (presuming the problem is because of the higher resolution than the Nexus 7)?
Re: Problem with Performance when using Helicon Remote
Which version of Helicon Remote is that? Check in the app's menu (button in the top right corner) - About.
And which version of Android is this device running? That's in the Android system preferences - About, or something like that.
