I am using Helicon remote, both directly with Nikon Z lenses and Nikon Z8 and Stackshot in standard configuration. So far so good.
I also tried it on the long rail that's available for Stackshot (https://cognisys-inc.com/focus-stacking ... -rail.html) but could not get it working correctly.
Are there any settings that need to be changed?
If it's not possible to run it right now, could this be made possible for a future release?
All the best
Andreas
Stackshot - extended length rail
Re: Stackshot - extended length rail
Hello Andreas,
I don't think anything needs to be changed, it should work. How exactly is it not working?
Did you just replace the rail connected to the same controller box that worked with the standard rail? Or is it a different controller?
