It's no longer possible to access the forum from within the Vivaldi browser. Login hangs at Cloudflare checking in a seemingly endless loop.
Mark
access to the forum
Re: access to the forum
I tried in the current version of Vivaldi on Windows and don't see the problem, it's likely not related to the browser. Do you have VPN enabled in Vivaldi? If yes - that's probably what Cloudflare flags as a highly likely bot / automated access.
- photophart
VPN was on. Turned it off. Problem persists.
Mark
Mark
Try disabling all browser extensions. Either something is messing with the Cloudflare page so it's not working properly, or Cloudflare really doesn't like your IP address. There's pretty much nothing we can do about it (and we need the Cloudflare protection because someone is attacking the forums all the time). Since it's related to the browser you're using - it's probably the extensions.
- photophart
Problem has resolved itself. I changed a few things in the browser as per your suggestions t no avail. Today, magically, cloudflare let me in. Mysterious but a relief.
Mark
Mark
