Can't get past F9 to load message
karldz1
Post by karldz1 »
Program tells me I need to press F9 to load. I tried it with and without using the fn key and my fn is not locked. Please advise.
Re: Can't get past F9 to load message
You don't need to press F9 and you can't "get past" this message, it's permanent. It's just a feature in the program that you can trigger with F9. If you're using Focus 8 - pressing F9 works and the issue is probably with your Fn key. If you're using Focus 9 there is a known issue that will be addressed soon, ignore it altogether.
