Is it possible in version 9.0.x to add an option to save a custom workflow and then load and run that workflow when processing another batch?
This would greatly speed up the workflow when using the Stack Outputs method, especially if the user combines multiple rendering methods.
To explain what I mean, here is an example:
I process one batch using several different methods, for example:
* A: radius 25, smoothing 4
* B: radius 8, smoothing 4
* C: smoothing 1
I then use retouching or the Stack Outputs method to overlay/combine all three methods (A, B, and C) in order to achieve the final result I want.
If I want to process another batch using exactly the same workflow, I currently have to set the parameters for all methods A, B, and C again.
It would be very useful if I could save my workflow (A: radius 25, smoothing 4; B: radius 8, smoothing 4; C: smoothing 1) and give it a name, for example **“render_A24_4B4_8C4”**.
When processing another batch, I would then simply select my saved workflow **“render_A24_4B4_8C4”**, and the new batch would automatically be rendered using the saved settings:
* C: smoothing 1
The resulting rendered files would then only need to be combined using retouching or the Stack Outputs method.
Thank you.
Helicon Focus 9.0.x - save a custom workflow
Re: Helicon Focus 9.0.x - save a custom workflow
It's not possible yet, but it is on our to-do list for the near future.
