Green metallic Halictid bee
Charles Krebs
This is from a stack of 41 images. Photographed using a compound microscope with a low power objective.
- 6001_6041sh1.jpg (144.63 KiB) Viewed 40932 times
Artshot
I wonder how many times I will have to write on the blackboard...
I will not be jealous of Charles.
I will not be Jealous of Charles.
Hmmm... it's going to take a LOT of chalk before THAT works...
Because I am VERY jealous of Charles!!!! LOL
What great work. Just SO nice.
OK... back to the blackboard.... sigh....
Dan Kozub wrote:Tom,
Have you got your Zigview? You've promissed to beat Charles after you got new camera : ))
There is NO way that I'm going to even come close to beating Charles! The closest I'll come is just sitting here drooling over his images. But, I'll bet I'm MUCH better than he is at drooling!
The Zigview FINALLY arrives tomorrow. I have a deadline to finish by the 2nd and after that I'll turn my attention to seeing if it's going to be hekpful or not. I sure hope so, it's expensive enough!
But, I'll have to make sure I don't use it just after viewing Charles Kreb's photos. I don't think it's waterproof.
I'll be experimenting with LEDs, Macro Flash units and continuous lighting... usually in some combination. Since I'm working in a studio enviroment, combining sources, as long as the color temperature matches, is useful.Dan Kozub wrote:I think lightening is the second most important point after camera choise.
Do you use LEDs? I've heard some microscopists use fibre to deliver light right to the subject
Sorry I didn't catch your question earlier.
Oddly enough, it's sometimes toughest to determine the color temperature of a camera's internal or external flash than it is to find the reported color temperature for other types of lighting. But, it's generally around 5500K-5600K.
Most of the lights I use for smaller subjects fall between 5000K and 6500K... which is the range comprising daylight sun. So, mixing the flash with the other lights is no more or less difficult than using the flash as fill for outdoor imaging. Mid-morning is generally 5000K (D50) and around noon the light would be in the 5500K (D65) range and an overcast sky might be 6500K or greater.
I simply look for 'full-spectrum' or 'daylight balanced' continuous lighting when combining it with a flash unit. While not EXACTLY the same color, it's usually close enough not to give me serious problems.
