x64 Issue ?
g0b
x64 Issue ?
Post by g0b »
Just bought Helicon Focus X64. But when I run it, I only see a 32bits process running.
I've tried to run HF as administrator as said in a previous thread, but it does not fix the problem.
I'm running HF 5.0 under Windows 7 x64. Any clue ?
g0b
Re: x64 Issue ?
Helicon Focus runs 64 bit processing server for calculations if you have 64 bit OS and X64 license.
g0b
Re: x64 Issue ?
Post by g0b »
I can't see any process called "HeliconFocusServer64.exe" in task manager. and HeliconFocus *32 seems to do all the job. What can be wrong ?
g0b
g0b
Re: x64 Issue ?
Post by g0b »
In fact, it seems "HeliconServer64" is not launched with raw files. is it normal ? but with bitmap files, it is here and working :-)
g0b
Re: x64 Issue ?
This is strage, the server should be launched for all kind of files. Please check again and send us one of the raw file for tests.
