Labelling and/or Watermarking
rogerbarnett
Post by rogerbarnett »
Hi Guys,
We've just purchased Helicon Remote and Helicon Focus for photographing various laboratory samples. Finding it really useful, but one slight flaw. Is there an an easy way to put a label or a watermark onto an image in Helicon Remote? The facility is certainly there in Helicon Focus for focus-stacked images (the Text/Scale box), but if there's a similar feature in Helicon Remote for the single images then I can't find it.
Not after anything fancy, all I'd want to do is be able to overlay the filename, or a unique ID number into the corner of the image as white text. That way, we can keep a central directory of all images. Most importantly, if an image is printed you wouldn't be able to see the filename, but if there's an ID number on the actual image itself you can always look it up and it's traceable.
If Helicon Remote can't do this, is there a third party bit of software that can do that? Just load a JPG, and burn the filename onto the bottom left corner in white or black letters or something?
Thank you.
Re: Labelling and/or Watermarking
Thanks for your suggetion. We would not like to add such a functionality to Helicon Remote. First reason is that Helicon Remote is primary designed to prepare stacks for Helicon Focus and texts on source images will prevent images from being properly aligned. Second reason is that even simple feature as adding watermark requires a lot of interface controls and we do not want to overload interface with functionality which is not essential.
Please have a look at Helicon Filter. This is image editor that has a function of putting a watermark on the image. It can also work in batch mode to process all your images at once.
We appreciate feedback from our users very much. If you have some suggestions or ideas, we would be happy to discuss them.
