Error Running HeliconFocus Server?
Ben2011
Post by Ben2011 »
Hello!
I installed the trial version of Helicon Focus 5.2.15 and tested it using the images under the directory
\Helicon Software\Helicon Focus\images\Helicon Focus Samples
It worked pretty well using the GUI mode, but then I tried the command line mode, following the instruction on this page
http://www.heliconsoft.com/focus/help/e ... ation.html
As I input
HeliconFocus.exe -silent "C:\Program Files (x86)\Helicon Software\Helicon Focus\images\Helicon Focus Samples"
The application starts, but then failed with dialog "Error Running HeliconFocus Server"
So could anybody here give a hint for this?
Thanks a lot!
Ben
Re: Error Running HeliconFocus Server?
We were not able to reproduce this bug in our environment so we need more info:
1. Windows version
2. Registration status and license (look at the menu\Help\About box )
Made one more test after rebooting Windows or after killing HeliconFocusServer*.exe process.
Please send us this info to [email protected] so we can prepare a test version for you.
In the meantime, disable Use 64/32 bit processing server in the Preferences of Helicon Focus.
Lars
Post by Lars »
Hello there,
I am currently experiencing the exact same bug. Software starts processing, then throws described error, but still works all the way through the progress bar after and returns an output image which seems to be a copy of the last one of the images to be stacked.
All works well without 64bit server enabled.
Win version: Win 7 Pro 64bit
Software version: Helicon Focus 5.3
Registration status: Trial licence (downloaded today, 2013-09-30), plan to purchase after trial expired
Best regards,
Lars
That is strange, this bug was fixed a long time ago. While we are trying to locate and fix this bug,I would recommend to check version 6 which has more version.
