Nikon D7000 & Asus Transformer Prime
Re: Nikon D7000 & Asus Transformer Prime
Does Android itself see the camera? Is there a pop-up window when you connect it? Can you browse camera's storage from Gallery application?
Raab
I just bought cables to try this one out (using the the usbcable that you get with the TFP then a USB female-female connector followed by a cable that converts 'normal' usb to the miniusb). But nothing happends. The OS doesnt see it and the helicon doesnt either. Anyone who got this working?
Best regards
Best regards
Which camera? D7000?
I'm not sure what exactly is wrong, but must be a problem with cables/adapters, since Android itself can't see it. To check if it is a problem with camera or physical connection, you can try connecting USB mouse .
Same problem whith asus transformer prime
but it's working when i use the dock
so may be i think there is a particularity with the connector of the prime
I hope with the future tf300 or TF700 it's working
( i don't know the connector for this model
yeah you right.tanguy wrote:Same problem whith asus transformer prime
I think the problem of that the connector.
