More shots taken than expected
foodminer
Post by foodminer »
I used Helicon Remote for the first time today. The program indicated it was going to take 24 shots but ended up taking 168 shots. And it took forever to render the photo. What did I do wrong?
Re: More shots taken than expected
Please explain what you did exactly. For example, it's possible that you've enabled several bracketing options at once (focus bracketing , exposure bracketing, time lapse), thus multiplying the number of shots, without noticing it. If you're sure that was an error, if you notice it happening again - please try to reproduce it with a smaller number of shots and send a bug report (menu -> Help -> Report a bug, or menu -> Feedback -> Report a bug on Android).
Since it usually takes 5-7 seconds between shots, 168 shots is a long time. If it takes even longer - that's a problem, but under 10 seconds delay between shots is normal.
