When I load the list of 5 .nef images taken consecutively, and press RUN, I get the message to the effect
"Source Image Error"
"The dimension of the first and current images are not equal. etc, etc, etc."
I have to Continue, in which case the image is deleted, or Abort.
THe program then says that I can choose another RAW converter. I was using the default selection, Adobe RAW/DNG converter.
This didn't happen when I was using the trial version and had to use .jpg format.
Using the NIKON D7000.
THanks anybody.
Source Image Error - Dimensions not Equal
Re: Source Image Error - Dimensions not Equal
Does it happen with version 5 of Helicon Focus? Have you already tried version 6?
