Automatic labeling of output files is incorrect
brentbristol
While experimenting with radius and smoothing parameters for a set of source images I noticed that the automatic labeling of output files is incorrect. For instance if I set R=1 and S=4 the automatic labeling shows R=4 and S=1.
brentbristol
Re: Automatic labeling of output files is incorrect
When saving the files from such a parametric study the filenames do reflect the correct R and S settings, but the labels in the output list is where the problem is.
Yes, we know about this issue. It will be fixed in the coming versions.
