Prophoto RGB Color Space Not Applied
hac
Post by hac »
I am using HF 6.2.2. Whenever I export 16 bit TIFFs from Lightroom 5 to HF, the TIFFS I export are in the Prophoto RGB color space. However, when I run HF and save the resulting image, the TIFF that is saved is in Adobe RGB. Strangely, if I export the TIFFs from LR to my Desktop with Prophoto RGB as the color space and then run them through HF, the resulting image that I save is in Prophoto RGB. Seems that there is a bug in the way HF is handling files exported directly from LR.
Thanks.
Re: Prophoto RGB Color Space Not Applied
Thanks for this point, we will check it. Helicon Focus should preserve the color space from the source image.
