When I retouch and want to overwright the already saved picture from an enqueu stack I get a failure message. To save it in a new folder does not make any problems. Because I stitche the pictures later it is important for me to have ascending or descending order in the filenames.
The saved files (TIF) after retouching do not open in LightRoom. You can open it in PS save a copy and then open it in LR. I put the files to the FTP.
danibo/retouched_do_not_open_in_LR
hmmm
It corrupts whole workflow afte HF
How about the issue with the missing EXIF data?
danibo
Saving Problem after Retouching
Re: Saving Problem after Retouching
Hm, we cannot reproduce the bug with busy file, even on your stacks. I am afraid we will need more hints how to reproduce it. The bug with EXIF is still not fixed, we are working on it.
I enqueue render about 72 dng pixtures and save them to a folder.
Some of them I retouch and want to save them to the same place with the same name as the automated enqueu saving of the picture.
But then I am not allowed to overwright it...
Saving them to another folder ore using a different name is possible to save them but results in the problem, that Lightroom can not open the tif.... See other tread.
If you want I can upload all pix ore make you little screenmovie...
I have the same issues,when I stack only one picture... see attachments..
- Unbenannt_3.JPG (132.01 KiB) Viewed 7276 times
- Unbenannt_2.JPG (108.61 KiB) Viewed 7276 times
I suspect this could depend on OS and folder names.
1. Please let us know exact path to folder with source files and path of destination file.
2. Do you have Windows XP?
3. Please try the simplest workflow which is easy to reproduce. For example, open demo images from "c:\Users\...\Pictures\Helicon Focus\Samples", process, retouch, save, process again, retouch save with the same name. If nothing happens, try the same with short jpg stacks, then with tiff stacks, then with dng stacks.
Stas I did as you told me with HF622beta
with the sample images (jpg mushrooms) trying to save as tif.
same result.
Does not matter saving as JPG or Tif
As OS I use Windows 7.
danibo
same result.
danibo
- computer_OS_danibo.JPG (69.17 KiB) Viewed 7259 times
- hf622_no_overwriting_file.JPG (33.09 KiB) Viewed 7259 times
Very strange. Why the program looks like under Windows XP? Do you have XP style active or the program is run in compatibility mode?
it is 100 percent Windows 7
where can I check the compatility mode is on or of
