Selecting images to process
Guest
It is not so easy to select the pictures for merging.
I often have to go through the process of finding the folder in the slow folder tree, look through the tan and gray folders for the one I want, select my folder, deselect the pictures I want to merge, and finally choose the menu option to invert the selection. But there is a better way: the files tab should have a quick file locater as the main screen. Opening the folder, you should then be able to select the files and click "Add to dock" (the dock being the group of pictures to be merged).
