was 4.2.9 the previous version?
J_ph
Post by J_ph »
I installed 6.3 Mac but I can't drag and drop the files to process. But an older version that i have 4.2.9 works fine. I was wondering if there is another version between 4.2.9 and 6.3 that is available to download? I must have saved over the last version.
Also, 6.3 only saves the file settings in the default filename for method C, A and B will generated a normal "untitled" name when saving.
and... it appears that the same settings in 4.2.9 are creating very different results when used in 6.3. This may be my error, I need to test a little more...
thanks, j
