shorter delay between continous shootings
derschwarzeritter
Post by derschwarzeritter »
hello all,
just started to work with helicon remote, but already have a question which i could not find in forum:
i use helicon remote to set autofocus start- and end-point with some 3-6 steps. but i need to take 2 shots with short delay with each autofocus step, because i use automasking (like hensel freemask). therefore i need 2 shots within 2 seconds to enable flashlight control for front and background flashes.
i tried a lot with settings and prefs, but i could not shorten the time between the 2 shots, even when saving just to camera. is there a way to get this working? otherwise i cannot use HR for this purpose...
best regards - robert
Re: shorter delay between continous shootings
There's a limit on how fast the shots can be taken. If you take all the possible speedup measures at once, the fastest you can get is 2.5-3 seconds. I don't think 2 s is doable, at least not reliably.
