Zoom in LiveView not working
hjk
Post by hjk » 12.10.2016 15:53
I am shooting with Canon 5D Mark II and have the following problem with zooming in LiveView: whatever point I choose with mouse zooming always zooms to the same point in LiveView image. If I take an image zoom works fine but in LiveView not.
I have had this problem for a while and I did install Helicon Remote again, but this didn't help.
Henri
hjk
Re: Zoom in LiveView not working
Post by hjk » 12.10.2016 16:00
Also once I stack the images the resulting image has Helicon watermark in it "Created from xxx images etc....", and the resulting image is also of poorer quality. I have a valid license...
Henri
Post by Stas Yatsenko » 13.10.2016 09:40
Go to Helicon Focus menu -> Help -> Deactivate, restart the program and register again with your activation code to fix the watermark problem. As for zoom - it works fine on all our Canon cameras, do you have Helicon Remote 3.8?
It's possible that the problem is in the camera body settings, although not very likely.
hjk
Post by hjk » 13.10.2016 12:32
Thanks Stas,
I had 3.7.3 but deactivated + activated again and updated. Hopefully the watermark is gone. Watermark was not consistent but popped up randomly.
Regarding the other issue of zooming I went through all the settings I could think of and it turned out that it had something to do with the autofocus menu item in HR. Sorry my mistake, zoom works fine now.
Henri
Post by Stas Yatsenko » 17.10.2016 09:54
Good to know, thanks for the information.
Macphoto1
Post by Macphoto1 » 16.05.2019 16:25
I have the same zoom problem now - what was the solution you found?
Post by Catherine » 20.05.2019 20:38
Please update to the latest version of Helicon Remote from https://www.heliconsoft.com/software-downloads/
This should help.
Please let us know if it worked.
gto
Post by gto » 22.05.2019 12:28
it doen´t work for me. i sent a bug report
PJ Edwards
Post by PJ Edwards » 28.05.2019 09:05
I don't know if this will help at all:
I have the same problem: EOS5D iii (13.5 firmware) - everything on Helicon works well except clicking on the Helicon Remote liveview screen just causes it to focuss on the area that I most recently had set when using liveview on the camera. (Same for focus)
I've noted that changing the camera battery for a freshly charged one can sometimes get the feature going again. I Suspect there is something not being initialised correctly in the Canon firmware, so Helicon may or may not work depending on what state the camera is in when it powers off or even on which individual camera you were using.
Paul
Post by Catherine » 19.06.2019 00:26
Thanks for your reports. We've finally located the problem, it will be fixed in the upcoming version 3.9.9 that we're aiming to release this week.
STJohnson
Post by STJohnson » 08.07.2019 16:53
I'm having the same issue as well.
Is there a new release date for the updated version of Helicon Remote with the fixed issue?
turtlegurl
Post by turtlegurl » 29.07.2019 20:45
I'm interested in the new version too. Would you please post here when the production version is available? Thanks!
Post by Catherine » 14.08.2019 15:17
Helicon Remote v. 3.9.9 released: https://www.heliconsoft.com/software-downloads/
