I have a stack of 3 landscape images.The clouds moved from left to right in the background. Helicon Focus is shifting each image in the stack to compensate for the cloud movement, but of course this completely messes up the non-moving foreground elements, and leaves a strip on the receding edge where I lose data.
How can I prevent Helicon Focus from shifting images to the left or the right? I'm going to end up using only one image for the sky anyways, it doesn't matter if the clouds don't match up.
Clouds moved in background, HF shifting each image in stack?
Technetium
Re: Clouds moved in background, HF shifting each image in stack?
Please open Helicon Focus menu "Edit / Preferences... / Autoadjustments" and set "Adjust vertically: 0 %", "Adjust horizontally: 0%".
