RAW in—DNG out in the batch mode
maxsol
Post by maxsol »
Dear Stas,
I'm using RAW in-DNG out mode in batch, the source files are Canon Mark III .CR2.
The DNGs seems to be corrupted while Auto-saving to DNG.
Manual saving to DNG from the same stacked files works fine to me, no matter was it batch or single files mode.
The autosaved DNGs are quite less in size than the manual saved ones.
Also, some of file header's fields are incorrect:
- Missing "Application" tag (should be "Adobe DNG Converter 9.1.1 (Windows)");
- Bit depth: 8 instead of 16;
- Color mode - missing.
While the Camera Data EXIF are present and correct.
Manual saving to any format works fine.
Autosaving to either tiff or jpg works fine also, no matter what source files are. The only issue is the autosaving to DNG.
Is this a bug or just a trial limitation?
Windows 8.1
HF release is 6.7.1
DNG converter - tried all the latest versions with same result.
Re: RAW in—DNG out in the batch mode
It's a bug, and so far we're unable to reproduce it. Can you give us one of your .cr2 files from a stack that produces this issue?
maxsol
Post by maxsol »
I uploaded source files and both output DNGs to FTP.
We were able to reproduce it. This is a bug of trial version. It will be fixed.
maxsol
Post by maxsol »
Thank you so much.
