I can connect my Samsung Galaxy S7 smartphone to my Nikon D7200 with a USB cable and everything works fine in Helicon Remote. Can I connect wirelessly? I cannot get a connection. If this is supposed to work, can you point me to some instructions to make the connection. What settings on both phone and camera.
Jeff
Connecting with Samsung Galaxy 7 phone
Re: Connecting with Samsung Galaxy 7 phone
Yes, it should work.
1. Run the app.
2. Turn the camera on, enable Wi-Fi.
3. Connect the phone to the camera's Wi-Fi network.
4. Go back to the app. Press "Select a camera". An "Automatically detected camera" item should appear in the list. Tap it to connect.
1. Run the app.
I can see the camera connect to a smart device but I do not see an automatically connected camera. It does not see any camera detected. Any ideas?
Try the following: go to Tools -> Network cameras -> Add, select Nikon for camera type, enter any name and 192.168.1.1 address. You will see this manually added item under "Select a camera". Turn your camera on, activate Wi-Fi, connect the phone to it. Then switch to the app and click this manually-added entry under "Select a camera".
