Can't connect Canon 6D to iPhone
Paul Lundgren
Post by Paul Lundgren »
I've followed every recommendation found and iPhone still says "camera not connected". I was able to connect with Cannon Connect easily – but not with Helicon Remote. I have deleted Canon Connect as suggested. Still no luck. Do I need a 1,2,3, list or something?
Re: Can't connect Canon 6D to iPhone
Make sure you run the app first, then connect iPhone to the camera's Wi-Fi network, then go back to the app, press "select a camera" and tap the "Auto-detected camera" item.
If you see "Camera refused connection" message, you need to reset and re-enter the Wi-Fi settings in the camera body, then repeat the steps described above. Select the "Smartphone" mode when configuring Wi-Fi in the camera body.
