Using Another Output as a Source
Locked
josh330
Post by josh330 »
I am confused as to how to use another output as a source when retouching. When I render a series of stacks I am able to use another output as a source. So it that instance it works. However, I haven't saved anything as a project yet.
But it doesn't work when I save an output as a project. For example, when I want to exit Helicon to work on something later I will save an output as a project. Then when I go back into Helicon later and open that project I can't use any other outputs as a source for retouching.
Does this mean that I need to do all of my retouching in one session!?!
Re: Using Another Output as a Source
We're looking into it and will fix the problem in the upcoming Helicon Focus 7.
josh330
Post by josh330 »
What is the estimated release date of Helicon Focus 7?
It's just my recommendation that Helicon should not say that output images can be used as a source for retouching. They really can't in the current version since I doubt users finish their retouching in one session.
We're working as fast as possible.
Locked
