Recommended Step Width for Canon Lens 180 mm Macro ?
chvfabercastell
Post by chvfabercastell »
Hello Stas (?)
Whart is the Recommended Step Width for Canon Lens 180 mm Macro ? (For the 100 mm Macro II You suggest 21 if i am right, but in the Configuration List of Canon Lenses, the 180 mm Macro is not visible...)
Thankx
Christian from Switzerland
Hec65
Re: Recommended Step Width for Canon Lens 180 mm Macro ?
Post by Hec65 »
Use step with 15 at F 10.
See as well attache JPG for combinations with RAYNOX macro lenses
Regards
Hec65
MPRABHU
Post by MPRABHU »
Hello Christian,
I see that you are using Canon 180 mm f/3.5 Macro lens which is Manual focus lens. Does it work with Helicon tube ?
Kind regards
Pantherman
Post by Pantherman »
I have the Canon 180mm Macro, and it is an auto-focus lens with an internal USM motor for focusing. Is the lens you have a Canon L series lens?
