Sony A7iii + Sony 100mm GM Macro - Focus step adjustments in app do not work
lensloops
Post by lensloops »
Hi
Newbie here. Have just bought Helicon Remote to use with my new 100mm macro…I’ve read the tutorials on set closets and furthest point.
I set the lens to autofocus and switch the camera mode to manual. On 100mm, the switch to manual is done on lens but the autofocus is still on.
I set the closest point using camera manual focus ring. I try to setup the B point using the arrows in app as I am not supposed to touch manual focus ring or autofocus, but when I use arrows, the depth of field does not change in live viewer, so no matter how many steps I put through, it stays focused on point A.
It feels like the app is not controlling the manual focus ring.
What am I doing wrong?
Re: Sony A7iii + Sony 100mm GM Macro - Focus step adjustments in app do not work
Set everything to AF, try resetting the camera body settings if nothing else helps.
brysonwong
Post by brysonwong »
Hi Catherine,
I’m facing the same issue with my A73 running the latest firmware. I’m using it together with the Sony 90mm F2.8 G Macro lens.
I’ve already tried resetting both the camera settings and the app, but the problem persists. The issue usually occurs right after completing the first focus-stacked sequence. When I try to start a second focus-stacking session, the shutter won’t fire, the focus appears to hang, and the app displays a prompt asking whether I want to abort or continue waiting.
Has this issue been reported before, or is there anything else I can try to troubleshoot it? Thank you for your assistance.
Please send a bug report after this happens: menu - Help - Report a bug.
Also try removing all memory cards from the camera and shooting without them installed.
