I have been evaluating ver. 3.10.3 (the current version), and found I was obtaining pretty bad results on my two PCs (a Compaq laptop and a Gigabyte desktop). Since my results were obviously not comparable to those I have seen in reviews of Helicon Focus on the web, I did some searching and came up with two older versions, v3.00.2 and v3.10.1. The first of these versions works fine, the second displays the same problem I got with the present version. By swapping individual files in and out, it seems that the bug is in focus.dll v3.10.1 and later. As soon as I drop focus.dll v3.00.2 in the v.3.00.2, I get the bug also in this earlier version.
Attachments are pictures reduced to 1/8 of their original size, made from the same set of 7 pictures, same default settings. Results speak for themselves.
Best regards,
ES
bug in ver. 3.10
Guest
bug in ver. 3.10
- small_ver3.00.2.jpg (90 KiB) Viewed 13319 times
- small_ver3.10.1.jpg (90.8 KiB) Viewed 13319 times
Guest
John
Focus issues with 3.10.3
I have had no luck with this filter. As the program "stitches" the images together it off-sets them. The resultant image is as if a number of exposures have been made with the camera tilted slighty for each one! I imagine the effect is a focus issue. Very worrying! Have Helicon addressed the issue? Another post suggests the same problem so don't think it is my inexperience with the program.
To be 100% sure, please send me the result image to [email protected] or post it to this forum.
