Images not sorting
cauyeung
Images not sorting
Post by cauyeung »
I have checked the sort ascending box but the images are not sorted in the order I've taken them. Any suggestions?
Re: Images not sorting
Can you send a screenshot? Maybe we will see the reason why this happens.
cm-helicon
Post by cm-helicon »
I do have the same issue. Images are not sorting :-(
IMG_10
IMG_13
IMG_11
IMG_12
IMG_14
IMG_09
Would be anyways nice to be able to sort them manually too.
Very strange, how do you add them? Do you use click first then ctrl-click last file to select them? Do you drop them to Helicon Focus? I suspect the sorting is not working for some specific method of adding files.
alash
Post by alash »
I experience the same problem, images imported by selecting as you described (click first, ctrl+click last, drag into HF) - not sorted either by date or name...see the attached screenshot.
not sorted.jpg (84.75 KiB) Viewed 5631 times
What OS version and Helicon Focus version do you have? Please contact us via [email protected]
alash
Post by alash »
...so I have solved mine problem - the problem was that there was "e" as the first letter in some of the jpgs and "E" as the first letter in others - HF is obviously distinguishing them...so actually sorting works in my case, only the sorting rules might be somehow uncommon. Alex
btw. there is a limit on how often one can submit a post to this forum? That's rather strange - I suggest to cut this limit dramatically or remove it completely...
