Galaxy Tab A connection
fielderda
Post by fielderda »
I've got a new Galaxy Tab A (Android 5.1.1) and connected it to my Canon 80D with a OTG adapter (attached)
OTG .png (94.7 KiB) Viewed 5392 times
with the cable that came with the device. Helicon Remote doesn't recognize the camera.
When I use the cable that comes with my Canon 80D and use the other OTG adapter, then Helicon Remote recognizes my camera.
Here is the problem:
Helicon Remote on the Galaxy tablet controls all the functions of the camera BUT it doesn't show the Live preview on the tablet.
It only controls the LiveView on the camera. If I connect my camera to my laptop with a USB cable, LIveView on the camera is disabled while Helicon Remote is running and works as it should.
Any ideas?
Thanks!
Screen Shot 2017-12-30 at 3.33.37 PM.png (96.55 KiB) Viewed 5392 times
fielderda
Re: Galaxy Tab A connection
Post by fielderda »
After playing around with my Galaxy Tab A tablet and my USB connect, I finally figured out the right steps to get the USB connect working:
- Turn on Camera (80D)
-Connect USB cable from Camera to tablet. (Connecting after can cause LiveView not to operate)
-Turn on Tablet
-Active Helicon Remote and wait until camera is recognized
-Focus stacking works just fine.
One BUG: If you click on Tools/Focus Stacking, a blue file folder appears. There doesn't seem to be a way to exit out of this window.
The only way is to reboot the tablet and start again. Stay away from this setting is my advice.
Hope this helps someone out.
mrose
Post by mrose »
You should see a "CLOSE" button at the bottom left.
There's that "Close" button as mrose points out, but either way, you shouldn't have to reboot the tablet, in the worst case you should be able to simply kill the app. So I'm not sure we're talking about the same thing here; perhaps, something in the app doesn't work on your tablet as expected. If this reply doesn't solve your problem, please share a screenshot (or simply a photo) of the screen while this is happening.
